Almot
Oct 10, 2017Explorer III
htwheelz67 wrote:
the initial investment is way more but when you factor the life of the LION batts, the fact that you can discharge them 100%, the weight and space savings,how quickly they charge, when you compare everything "apples to apples" the LION batts are much cheaper per amp hour than lead acid or AGM's.
A few corrections here.
1) Not 100% discharge. 75-80% is more likely, if you want them to last. (And max charge is also desirable to limit by 80-90% of nominal capacity).
2) Cost should be compared "per cycle", not per AH :)... Flooded are probably cheaper per cycle.
Faster Li in the last 15-20% of charge, yes.
OP - how are you going to charge them?
ps: sorry, have just noticed the answer - generator. No further comments.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
