ABendage
Oct 24, 2017Explorer
ependydad wrote:
YES! But first, the rig has to go on a major diet. I don't have the available carrying capacity in the trailer to add solar.
How much solar do you want to add? You could use flexible panels and each 100 watt panel weighs 4 lbs. 400 Watts of panels, controller and wire would be less than 100 lbs for sure, probably closer to 50. I’ve never even considered weight when adding solar.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
