- TakingThe5thExplorer
DrewE wrote:
The question wasn't about using gray water to flush out the black tank, but using it to flush the toilet. I think I've read here of one or two people who have rigged something up to do that. It's basically just installing a suitable pump and running some water lines to it. Probably having a selector valve to let either the fresh or gray water be used for flushing (and a check valve for the fresh water line to prevent any possible cross-contamination from the gray water) would be a decent idea in case one needs to go potty before anyone has taken a shower or washed the dishes.
Note that the gray water can get pretty stinky over time. For the amount of fresh water that would be saved, I don't think I would bother. RV toilets don't need a lot of water to flush.
I have a grey water flushing system installed in my 5th. I have two grey water tanks and I only flush using the shower and bathroom sink water so the water is pretty clean. I can select fresh or gray water for flushing. I have a separate pump and filter for the grey side. Our problem was that the grey shower water tank would fill up 1st while the fresh water tank would become empty 1st. The grey water system creates a perfect tank balance and we are not afraid to use adequate amounts of water for flushing. I use black tank chemicals but put them into the grey tank where they get dispensed over time into the black tank. The system works well and extends our stay by several days. - theoldwizard1Explorer II
Anything "special" about the pump and filter you are using ? Could you share the brand and model numbers ? - TakingThe5thExplorer
The filter I use is a "bowl" filter with an element that is more like a screen then a filter which is good for catching hair and can be cleaned. The pump you will use should almost be equivalent to your own fresh water demand pump but make sure it cannot out-pump the freshwater pump. I have check valves in my system but in any event I do not want the grey water pump to be able to overpower the fresh water pump head to head, just as a further safety precaution. Like the fresh water pump, the grey water pump should be a demand pump.
I can look for model numbers for you tomorrow. - BobboExplorer IIGray water stinks as bad as black water. I wouldn't want that in my toilet after you flush.
- Before I got a trailer with a Sani-flush, I would drain the black tank first...leave the black tank valve open....Then......Carefully remove the end of the hose from the dump station hole and hold the hose up in the air, higher then the tank and reach down and open the grey valve. The grey water would run into the black tank 'til it equalized...tricky part was shutting both valves while you continue to hold the hose up. And there would be a little "mixed" waste water in the hose while you got it back to the dump station hole. I suppose you could install a third valve to manage that though.
- valhalla360NavigatorGray water often smells worse than black.
No thanks. - BarneySExplorer III
Just get a Valterra Twist On Gate Valve and put it on the end of the drain pipe just in front of the slinky. That way, you can close the valve, open both grey and black valves, and the liquid will equalize without going down the slinky. When done, close one of the tank valves, open the Valterra and drain as usual.
It looks similar to this one but without the clear plastic elbow.
Barney - mikestockExplorer
I have a clear section of sewer pipe and the first glug of gray water is pretty nasty with solids and coffee grounds.
After having trouble with my air admittance valve, changing it out, I still got a smell from my washer closet. We now, meticulously, clean all partulates before washing dishes. It's a little trouble, but got rid of the smell. - mockturtleExplorer III think some of you guys are just bored. :R ;)
- mikestockExplorer
Barney
I like the method that Vintage465 uses. I do the same except I can twist my outlet manifold upward to stop the flow through the hose. Just a quick way to do a little extra wash of the black tank. The more gray water you have the better it works.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
