wtravlr1's avatar
wtravlr1
VALTERRA WASTE GATE MOUNTING POSITON
I can't seem to find anything on this. Taking out the cable driving waste valves. May need to put in new waste valve with the handles in the down position. Is there any reason not to position them with the handle down instead of up or sideways?
  • Lynnmor wrote:
    Maybe I need to clarify, I was not speaking about leakage but rather the potential issues with "stuff" getting in an area where it can cause difficulty with valve movement. Read the instructions if you need to verify this.
    If you can give me a lead to where any instruction for correct angle of install for any of the waste valves might be, I would appreciate it. I cannot seem to find any manufacturers that speak to the angle of valve install. thanks
  • Our Winnebago came with one of the grey tank handles facing down. Easy to open.....kinda hard to reach in while bent over and pull it up to close it. No leaks at all.
    thanks!
  • My 23 year old Bounder came with both gate valves mounted with the handles down . NO PROBLEM.
    Richard
  • MrWizard wrote:
    I think you will find the instructions say to mount facing up or sideways
    Down may allow for liquid to creep into the pull shaft area , dry up and bind the shaft
    Also easier for the cable to operate pulling and passing side ways, that with a 'U' bend in it
    Have you looked at the mounting on your Bounder? The may be mounted with the handles down.
    Richard
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
