myredracer's avatar
myredracer
Explorer II
9 years ago
Mounting question on Valterra sewer hose carrier
Would like to install a sewer hose carrier under our TT between the I-beams which are 6' apart and not sure how to mount it. Valterra makes a fixed length 94" carrier and an adjustable one 50-94". The next shorter one is 64" long. Their photos show the saddles at the ends of the tube. Do these slide along the tube or are they glued in place at the ends? Would like to use the full 94" length which would mean the saddles would need to be about 1' from the ends. Can you cut the fixed length one and shorten it? But how would you reconnect it - is there a coupling that will work?
Valterra does have just a saddle available but there are two types. Can't tell if the one in middle photo glues on or if you add your own strap? Does the one is last photo need to slide on from an end or can be put over any spot along the tube? It looks like maybe you must have the saddles at each end because the end cap attaches onto the saddles?
