- wtravlr1ExplorerUPDATE: The valves will be adequately secured and have enough ground clearance. There should be no problem with valve stability. Just more convenient to mount with handle in down position. I can see a problem with seepage in to handle. Can't find any installation instructions from companies like Valterra.
- TakingThe5thExplorerDon't know what your ground clearance might be, but a handle pointing down could manage to snag something. Might bend or brake something and/or might be creating "a new dump station".
- ScottGNomadNever seen them mounted down but seems dangerous. If you have to mount them that way, perhaps you can secure them with something.
- MrWizardModeratorI think you will find the instructions say to mount facing up or sideways
Down may allow for liquid to creep into the pull shaft area , dry up and bind the shaft
Also easier for the cable to operate pulling and passing side ways, that with a 'U' bend in it - Dick_BExplorerOne thought is that it would be more difficult to hand operate them in the down position than to the side.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
