Hi Will,
Sorry this took so long too...LOL work has been off the wall and has had a severe impact on my camper forum habit... But I'm back and here goes on your questions.
Fisherguy wrote:
Hi John, been really busy lately and just now got caught up on this thread, thanks for the in depth reply, here do you find the time to help so many people like you do? You're a big help to a lotta people on here.
My water heater has an anode, it's a PITA to remove it everytime to drain it, is there something I can get to make draining it easier? Right now when I drain it I always have this thought in the back of my mind that there's water getting in the seam between the tank the the trim around it even though it seem well caulked, must be something I can do?
Thanks for the good words. Much appreciated. Now to your HW heater, it sounds like you have a Suburban heater? Is this correct? The anode is only used on the Suburban. I have the Atwood and there is no anode. I can easily install a drain valve in the Atwood.
Here are some options maybe, A pic of your setup may help may help spark an idea. I have some thoughts on a drain valve setup using the anode and still leave it in, but not knowing what room you have to work with they may go out the window real quick... or spark another idea.
Do you have an air compressor at home? That is another option
Guess I could drain/clean the filter after every trip, but I wish my housing had a drain on it, it's a little awkward unscrewing it where it is in the cabinet.
If they buried the filter canister housing under the sink and there are cabinet draws in front of it... Gee thanks... Yeh it is the cheapest way to do it, but a royal pain in the neck to service. If this is situation, for me, I would unhook the filter, connect the water line and remote mount the filter. Or do away with the filter and use other options on a camper water program that does not need an under the counter sink filter.
On my last camper, I did use a point of use filter before the sink. With that layout I had a cargo hole right next to the kitchen. It allowed me to remote mount the filter and I can take the entire filter out and connect the hose ends to either use the filter or not. Here is that setup
This one was a 0.1 micron ceramic carbon unit. Again I could remove it, drain it, clean it if I needed to. Which I really never did have to clean it as the source was so clean pre-filtered. Then I dried it out in the sun to store in the house in a clean vented plastic storage box in a dry cool place.
On my current camper, I added a similar remote point of use filter with this same setup, however I have found I really do not need it as I filter everything going into the tank.
There is also the Britta options, some of the pitchers are more conducive to an RV fridge now. This gets rid the camper sink filter all together. Ideally if you go this route you use the Britta at home too as those filters are not really cheap either.
Filtering the water when filling is probly a good idea, so what's a good filter to use when filling that will filter the bad stuff but not the chlorine?
There are lots of filter options. The issue is more what do you want to accomplish with filtering and then what to do with it after the campout?
These guys are pretty good and they do not say, just do this and all your problems will be gone. Which is the 1st thing that makes me respect them. There is no one size fits all in filters.
http://www.rvwaterfilterstore.com/ABChoosingASystem.htmYour simple question had 2 parts to it.
A. What is a good filter when filling?
B. but will not filter out the chlorine?
If you do not want to affect the chlorine, then you are after a sediment only filter. It just takes "particles" out. This is a canister filter with disposable cartridges and are sometimes "reusable" that you can wash if they get plugged. Which is good thing.
http://www.rvwaterfilterstore.com/ABFiltration.htm This page has a link to sediment only filters. The pleated one are claimed to be "reusable". Now comes the micron size. The RV filter store recommends 5 micron for the sediment filter. And if all you are worried about is particles, that is a pretty fine filter. 5 micron is 0.0002” Yes, 4 decimal places or less half a thousandth. You are not going to see by eye a partial that small. 100 micron is 0.0039” or 4 thousandths. Coming from a machine shop background, I can just see 0.004” if it is held to the light just right.
If all you are after is protecting the water pump and trying to get particles you can see out, well 50 to 100 micron will do that. Even a 20, or 5 micron can help if they do not plug on your water source.
I would pick an all plastic/synthetic pleated cartridge. This Flow Max series would be where I would start if I was going this way. I can clean it, and then dry it out in the sun. And after digging this up, I may add one as a pre-filter in front of my ceramic carbon filter. They sell the 5,20,50 and 100 micron which are washable pleated and the pressure drop is attractive along with the gpm. The finer ones they do not say they can be cleaned. And if your looking on gpm, much less than 2.5 is a real bear to fill the fresh tank. 42 gallon system at ~ 2 gpm is 21 minutes to just fill the system. But 1 gpm as a point of use filling a glass of water is tolerable.
http://www.freshwatersystems.com/specifications/FlowMaxbrochure.pdfThe FM series on page 4 of the pdf
Flow max is by Watts
http://www.watts.com/pages/_products_details.asp?pid=5753They sell the filters on Amazon or other filter places. Just get the size to fit the right canister. And some canisters have a clear cylinder so you can see how good or bad it if before opening. You can experiment with the sizes. Finer size (lower numbers) filters more and plugs faster. Here is a 50 micron on Amazon
http://www.amazon.com/Watts-FM-50-975-Flow-Max-Micron-Pleated/dp/B005XTY6C6Just to note, I have not bought the Watts, yet anyway. I use the ceramic carbon and deal with the chlorine. But like I said, I will look into getting a 50, 20 and a 5 micron cartridge and experiment as a prefilter for the ceramic carbon. If you get too fine, in the 1st stage it will drive you nuts clogging trying to fill the fresh tank.
This much I can say, 1 micron filtration will plug quick if you have a high iron source. One camp we go to that has high iron, I use a 100 micron Camco carbon filter so I can use the camp water on full hook up as my ceramic/carbon 0.9 micron will not work direct with all the iron. For folks who have tried filters and give up on them as they plug too fast, well they are doing their job just they may have selected one too fine as a first stage filter. Most times this is done in 2 or 3 stages if you are going down to the less than 1 micron.
I'm not a big germ-o-phob like a lotta people, I don't use paper towel on the doors of the handles of the bathroom door at work, don't use hand sanitizer etc and I think overall I'm pretty healthy but maybe I could do a little more for the water system..?
Thanks
Will
If you get the sediment filter it will help with the particles and leave the chlorine alone. If your after bacteria, taste, reduce chlorine etc. the carbon filters start coming into the equation and it starts reducing the chlorine, how much depends on how fine a filter and how high the chlorine was to start with. Then you need to start adding your own chlorine if you went too low.
Hope this helps
John
