Almot's avatar
Almot
Explorer III
Dec 11, 2019
Water filter upstream of the pump?
Thinking to add a sediment filter (and a proper strainer instead of a tiny strainer that came with my pump).
With my plumbing it's easier to install it upstream of the pump: tank -> 50 or 100 micron strainer -> 5 micron sediment filter -> pump.
I see most people installing filter downstream of the pump: tank-> strainer -> pump -> filter.
Is there any reason not to install the filter upstream, other than risk of pump running dry when filter clogs?
Also, what is your experience with <= 0.5 micron block carbon filters after sediment filter - is water pressure still tolerable? Shower is where my pump is definitely struggling. As much as I don't want any cr-ap on my skin and on remaining hair, I have doubts about carbon in this scenario.
  • The pump may have a harder time pulling liquid through a filter as opposed to the simple strainer. Prefilling the filter might help to get the flow started.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
