pbeverly
Sep 13, 2025Nomad II
I removed all my low point drain plugs and replaced with valves. Much easier to open/close and no tools required.
- StirCrazySep 14, 2025Moderator
how does that help with the water heater?
- bid_timeSep 14, 2025Navigator
By my way of thinking, it would seem to indirectly indicate you could but a valve on your water heater drain also. But that’s just me.
no the plug he is talking about is like on my camper.. where you would expect to see the "anode" there is just a nylon plug as the tank inside is lined or coated so you don't need an anode to prevent corrosion.
but I wonder if you could thread a valve in there, it would be big that's the only issue
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
