opnspaces
Sep 13, 2025Navigator III
Yes I think you will be able to remove the nylon plug and even more importantly reinstall it. As said put a bit of Teflon tape on the plug to help seal it if needed. Also don't go monkey tight on the plug. I usually install my nylon plug by hand and then about 1/2 turn more. If it leaks just tighten a bit more.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
