StirCrazy
Sep 14, 2025Moderator
how does that help with the water heater?
bid_time
Sep 14, 2025Navigator
By my way of thinking, it would seem to indirectly indicate you could but a valve on your water heater drain also. But that’s just me.
- StirCrazySep 14, 2025Moderator
no the plug he is talking about is like on my camper.. where you would expect to see the "anode" there is just a nylon plug as the tank inside is lined or coated so you don't need an anode to prevent corrosion.
but I wonder if you could thread a valve in there, it would be big that's the only issue
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
