Hey y'all. We have a 2012 Forest River Shamrock 21SS Hybrid. We do some boondocking and I want to up upgrade the water pump. Can someone tell me what the flow rate is on the factory one, since I canno...
Without knowing what you might have, why not try a test as home with a measured container. Run the pump and fill the container, then connect to city water with a pressure regulator and see how much faster you fill the container.
You could also fill the container as a house tap with city water, and then through a regulator to see how much slower it might be.
I just wonder whether the tiny lines in most RV's might be restrictive as well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
