4x4van
Apr 20, 2018Explorer III
Bumpyroad wrote:Seriously? When have you ever wanted to run your water (in an RV) for 20 minutes straight? That's +/-70 gallons, give or take (assuming a flow rate similar to a typical 3.5gpm onboard pump).:S4x4van wrote:
Actually, I think it did go over your head, at least a little. Why would he have to hit his switch every 15 minutes? That would only be necessary if he wanted a constant non-stop flow of water all day long.
what if he wants the water to flow for 20 minutes? now you would need to keep hitting the switch all day long whenever you wanted water. seems like rube goldberg had some input into the design.
bumpy
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
