nazpaz
Jan 14, 2015Explorer
Ron3rd wrote:
The only negative I've read about the standard Allure in in regions with huge temperature swings, ie, freezing then heat. Possible to see some separation in these cases.
Since we're fulltime the RV never sits out in the cold without heat on so the issue may be different for us than for a weekender in the north. It that case it's likely a real concern.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
