Randu
Feb 27, 2013Explorer
jrichard wrote:
....I still need to go to my trailer and figure out which fittings I need to attach the female QD/valve assembly to the existing plumbing. .......I'm going to tap into that line where it branches off to feed the water heater, stove, or heater.
Most grills won't work unless you hook in at the tank area between the propane tank and the trailer regulator. All of the trailer plumbing past the regulator at the tanks are low pressure and grills need high pressure as they most all have the regulator built in with the grill heat control. Randu
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
