jrichard
Feb 27, 2013Explorer
Randu wrote:jrichard wrote:
....I still need to go to my trailer and figure out which fittings I need to attach the female QD/valve assembly to the existing plumbing. .......I'm going to tap into that line where it branches off to feed the water heater, stove, or heater.
Most grills won't work unless you hook in at the tank area between the propane tank and the trailer regulator. All of the trailer plumbing past the regulator at the tanks are low pressure and grills need high pressure as they most all have the regulator built in with the grill heat control. Randu
On the Weber Q, you remove the regulator and put the 1/8" MNPT - 250 quick disconnect in its place. If you don't remove the regulator, then you have to tap into the propane before the regulator on the RV.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
