Ron3rd
Apr 17, 2013Explorer III
joegage wrote:
I contacted Calore (caloreequipment.com) about this subject and spoke to a very nice and knowledgeable gentleman. He said that all that's needed is "RV Quick Connect Hose with 1"-20 Disposable Bottle Male Connection" which is SKU #100476-100476-72, available in various lengths. No need to remove the Weber regulator. He said contrary to so-called expert opinions, this regulator, in addition to the one on the trailer, will likely not reduce gas flow by any significant amount, at most 10%. I look forward to receiving my new connector and trying it out.
Yes, you can give that a try as some have done it and said it works ok. Some members have reported low flame and low btu output when leaving the Weber regulator on. I ordered the fitting from Calore to replace the Weber regulator for that reason. Let us know how your setup works.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
