Ron3rd
May 24, 2013Explorer III
boubou64 wrote:
I have a line all the way to the back of the RV as well as hoses already.
Do I need all the list as on the first post or is the part #401153 enough? will my current quick connect hose fit this fitting?
why are there some fittings 1/4 and this one is 1/8?
If your hose has the female quick disconnect on both ends, all you should need is the Calor fitting and the Watts coupler. If your hose has the threaded end (same threads as on a disposable tank) you will need a different adapter for the Weber if you choose to remove the Weber's regulator, which some leave on and are satisfied.
Here's a link to how I did the conversion, which basically borrows from jrichard's info:
Weber Conversion for Quick Connect on both ends
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
