Gonzo42's avatar
Gonzo42
When is a Cooler not cool?
On our very first trip with our new toy, I discovered that the "cooler" is nothing more than a plastic box. Ice certainly didn't last long. Capacity is labeled as 100 lb.
So I built an insulated box to go around it. I found several types of insulation and chose two. (1) is poly foam with aluminized mylar on one side, and (2) is corrugated aluminum which has air/plastic-filled cells and comes in sheet form.
I built all the sides of the box from the poly, mylar side out, then glued the aluminum cell sheet on the inside. Glued it all together, reinforced all seams and corners with aluminum tape covered with packing tape.
More of the celled sheet went on the lid. Total outlay is about $30.
  • I'll post pics soon. Won't have a performance report until we get back from Yosemite.
    Its the built-in cooler, labeled for a capacity of 100 lb.
  • qtla9111 wrote:
    Any info on how long the ice lasts now?
    I was wondering the same thing .... ;)
  • Was it a built-in cooler? Or just a stand alone type cooler? Seems pretty cheap either way. Your upgrades should help a bunch, and cost about half the price of a new, decent cooler. Pics would be cool.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 01, 2026
