ScottG's avatar
ScottG
Nomad
Jun 26, 2013
Which Dicor?
I'm going to install a new Jack ant. and need to use Dicor between it and my EPDM roof. I already have a tube of self leveling Dicor - would this be OK to use or should I buy the non-self leveling type?
TIA,
Scott
  • Bobbo's avatar
    Bobbo
    Explorer III
    If the surface is even close to level, the self leveling is fine.
  • The self leveling will work just fine, no need to buy anything else. Clean the area wilh alcohol, mineral spirits, or acetone. Do not use any cleaner with citric acid or petroliun distillates.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 13, 2026
