agesilaus
Aug 03, 2016Explorer III
I may be wrong but the black color of tires comes from the carbon black that is added as a UV protectant by the manufacturer. As GDeTrailer above points out the tire will deteriorate just from age independent of UV exposure. The heating cycle that the tire goes thru every time you move the vehicle around will tend to break down the tire structure by itself.
But it is your tire. Of course manufacturers used to offer tires in 'white wall' that would have done the same as you are considering and I don't recall anyone claiming that white walls lasted longer than blackwalls.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
