STBRetired's avatar
STBRetired
Wine cork backsplash
As was discussed on fulltimin's rebuild thread, DW and I decided to do some minor updates to the inside of our rig. First on the agenda was to replace some mirrors with a cork backsplash made from wine corks from bottles we have consumed.
This is the original view of the area we are updating.
and
  • We started gluing corks that we had previously cut in half lengthwise to the wall. We started at the outer edge with full corks so that any cuts would be in the corner where they are least visible.
    We tried to avoid having corks from the same type of wine close to each other. We also tried to use corks of similar diameters in each row so that they remained relatively straight.
    It took us 3 days to glue up the 520 cork halves required to cover the space.It took 19 corks across the back and 7 corks on the side to complete a row. There are 20 rows of corks. Since the wall finish is light, any areas which would be exposed between corks (since they ae not perfectly rectangular) were colored black with a Sharpie.
  • We pried the mirrors off of the walls, then marked the edges where we wanted the corks to end with some blue painter's tape.
    then
    We taped some paper down to the countertop to prevent getting hot glue on the surface.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
