Bill_Satellite
Dec 12, 2013Explorer II
Whew, glad to see that someone got the correct info. The 2 12V wires have nothing to do with the Sensar itself and they should not be disturbed. These are wired to a light or buzzer to remind you that the antenna is not properly stowed. The Sensar itself gets all of its power via coax so you just need to remove the old and install the new using the existing coax cable.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
