floridaguy's avatar
floridaguy
Winegard Sensar IV Installation Help
Looking for some advice. I'm replacing a Winegard bat wing, vintage about 2006 with the Sensar IV that I'm going to pick up tomorrow. Heavy wind damaged the mast and crank mechanism. The present bat wing, with Wingman, has a 12 volt, two wire connection made on the mast, as well as the coax connection on the mast. Looking at the Sensar IV installation manual, it appears the new unit has a wall plate that I'll have to install inside. The 12 volt connection is made at the wall plate, along with coax in and coax out. Presently my winegard video distribution box provides the 12 volts that is connected on the mast. How have others dealt with this change in installation wiring? I was hoping the installation would be simple hooking everything up like it was before. All help appreciated. Bob
  • You should be able to skip the part about the wall mounted power supply. The winegard video box will do it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,387 PostsLatest Activity: Aug 16, 2025
