's avatar
Anonymous
Jan 19, 2025
Wolf pup 16 ft 2022 outdoor speakers humming
So I have a weird one, camper dose not have batteries in it. But outdoor speakers are making weird humming noises when it's cold out like 0 and below. And sometimes when it's like 32 out. Not sure why but it is. There is no power source the solar is not hooked up either. Any ideas??
Will we need new speakers in the spring time??
  • Sounds like electrical interference from something. If there is an in -line fuse take it out and see if that stops it.
  • No power source? Meaning no batteries, no solar, no shore power, and there's STILL a hum from the speakers? I don't suppose you'd go for a poltergeist . . . .
  • That's really weird. There must be power somewhere. Does the noise happen even when it's dark outside? If only during the day I'm thinking it's the solar causing the noise. If so you can try throwing a blanket over the solar and see if the noise suddenly stops. When you say the solar is not hooked up how is it disconnected? Is it just a removed fuse or are the panels not plugged into anything or ????
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,360 PostsLatest Activity: Apr 13, 2025
