Damdifino's avatar
Damdifino
Working on the upstream side of water pump plumbing
I've discovered a pretty severe kink in the hose leading into my Shurflo Revolution 4008. It's near the pump, between it and the water storage tank, and I suspect it's restricting my water flow because the hose is quite flattened out. So I plan to install an elbow at that point. Question is, if I cut the hose to effect the repair, will water drain out, and keep draining under my kitchen cabinets, until the fresh water tank is empty? Do I need to empty out the entire system before I begin work?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 14, 2026
