4X4Dodger
May 23, 2015Explorer II
OFDPOS wrote:
Some have had a good experience with the zep others haven't.
I'm sure robatthelake and myself will get flamed here, BUT I totally agree with not using it !
Alot of times the gelcoat shine can be brought back with a good DA buffer !
Go on youtube and type in removing/replacing decals alot of good advise and of coarse some lame ...
I've never worked with the Zep before , but I would think you would still have to clean/prep the surface to put it on.
Doing that your half way there , might as well just put the decals on then put a couple coats of wax on and your done.
I could just see the Zep turning yellow or peeling after awhile !
There are plenty of really good Marine Gel Coat products out there that are good for your RV. Use them.
For the OP; I'd be interested in hearing more about how you got your decals off. I need to redo mine soon but I have an aluminum trailer.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
