Carriage went out of business about four years ago. Run into financial difficulties. They built a fine coach. They built different trim level. The Carrie Lite which was not light was built on a 101" width chassis and then then they had the Royal International which was built on a 101 in chassis and was the top of the line. The Cameo was built on a 96" chassis and was a trim level down. Thor bought the name rights to Carriage at auction and has said they plan to resurrect the name. Lifestyle bought the important stuff and built the coach with the same great frame as Carriage. They units looked even better then the original. If the unit was maintained it should be ok. If you can find someone who can inspect it for you if you are not capable that would be a plus.
