Luke_PorterExplorerMay 16, 201410" or 12" Lube DiskI see there are 10 and 12 inch lube plates. Looks like the 10" is more common. My "pin plate" is 13" wide. The hitch plate is 11". Any reason to get the 12"?
netjamExplorerMay 16, 2014Some hitches (like Reese Elite or Signature) specify the size to use. My Reese specifies 12" only. I don't think its critical though.
Related ContentLONG rear valve stems .....10" to 12"?10" hitch riser10"/400# Axle - Brake Servicing Questions"Tuner" for a V-10"10 watt" LED
