Road_Phantom's avatar
Road_Phantom
Explorer II
Dec 02, 2016
1/2 ton towable 5th wheel...Ha!
I have a 1/2 ton towable rth wheel, but pull it with a 2500 ram, Hemi. I would love to downsize to a half-ton truck for the improved ride, lower height and cheaper cost since my present truck has a lot of miles on it.
After looking at the gvwr of the half-tons, it appears that there wouldn't be enough left over for a cup and that cup better be made out of paper.
Most half-tons only carry around 1800 in the bed. Once you add the weight of a 5th wh hitch, your wife, dog, gas and whatever else you might want to carry in your truck, (wife and you estimate of 250 lbs) you already up to around 500 lbs. Now add the hitch weight of your supposedly 1/2 ton towable, 1350 for my cougar, and you're already over the 1800.
Anything you carry in the underneath storage up front adds to hitch weight and so does anything in the wardrobe and under the bed storage.
Am I seeing this wrong or maybe I should stick with a 2500.
  • Few if any so called 1/2 tons can safely or comfortably tow a fifth wheel. Ours has a gross of 5600 lb which theoretically could be towed by a 1500/F-150 but I wouldn't do it especially here in the west with our grades.
