theoldwizard1
Jun 25, 2019Explorer II
Every vehicle manufacturer over-rates towing capacity. Bottom line, it is all about weight, both gross trailer weight, hitch/pin weight, and gross combined weight. Even if you are UNDER these numbers does not mean you will ENJOY towing with a large load. Things like tires make a huge difference.
I would stay under 8,000 lbs trailer weight. Pin weight combined with your payload should be less than 1,500 lbs. These are pretty low for a 5th wheel.
About Fifth Wheel Group
