bid_time
Jun 30, 2019Navigator
2112 wrote:No one here can answer that question, only you can. But I'll give you my assesment. A reasonable estimate would be that 5th wheel has 1600 lbs ( give or take) of pin weight. If everything else in the truck weighs less than 400 lbs, per manufacturer's ratings you're good to go. If all in you're over your payload rating, it's up to you to decide if you're safe or not. In any event, it all won't crash an burn the minute you turn the key. Ulitimately, time could take a toll though.
So you're saying I can't do what I've been doing for the past 5 years? I'm shocked! Should I leave the FW at the beach and drive home without it? Rush to the dealer and pick up a 1 ton?
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
