camp-n-family
Jun 30, 2019Explorer
patperry2766 wrote:rollindowntheroad wrote:
Ok I finally give!!! I understand that I wouldn't be able to tow a 5th wheel. With calculations I've come up with the max I could even tow a travel trailer is 7,000 lbs. A far cry from what Ford advertises.
That's not correct either. Per the 2019 Ford trailer towing guidelines and based on the info from your original post, max tow weight is 10,700 lbs
2019 Trailer Tow
look on page 19
Yes, that's the listed "tow rating". What the OP is saying, and what most don't understand, is that once you load the vehicle with gear and passengers etc he only has enough payload left to support the tongue weight that a 7k trailer would have. Rarely will you ever get to anywhere near a vehicles tow rating without exceeding 1 or more other ratings first.
A travel trailer weighing 10,700lbs would have an average tongue weight over 1300lbs! That would exceed the receiver rating and nearly max out many 1/2 ton trucks on payload without anything else in the truck.
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
