rollindownthero
Jul 01, 2019Explorer II
patperry2766 wrote:rollindowntheroad wrote:
Ok I finally give!!! I understand that I wouldn't be able to tow a 5th wheel. With calculations I've come up with the max I could even tow a travel trailer is 7,000 lbs. A far cry from what Ford advertises.
That's not correct either. Per the 2019 Ford trailer towing guidelines and based on the info from your original post, max tow weight is 10,700 lbs
2019 Trailer Tow
look on page 19
You are correct. I called numerous Ford dealers and they all came back with a towing capacity of 10,700 lbs. That makes me fell much better. Even though a 5th wheel might not work, a TT will.
About Fifth Wheel Group
