tersctExplorerAug 18, 201912V PowerMy 5th wheel does not power off of my vehicle when connected to it. A couple of times after it has set for a period of time, with no power connected to it, the 12V battery needs an assist to get the f...Show More
PNW_SteveExplorerAug 19, 2019Now I am curious.... I am aware of the designation of one of the pins on the 7 pin connector is 12v supply. I assumed that it was not used as none of the truck/trailer combos that I have owned have charged the trailer from the truck charging system. How common is it to have that feature from the factory?
Related ContentAdding power outlets in slide with no wiringNo power on outside GFCI outlet12v power problemsNewbie power question12 Volt Power Issue
