tersctExplorerAug 18, 201912V PowerMy 5th wheel does not power off of my vehicle when connected to it. A couple of times after it has set for a period of time, with no power connected to it, the 12V battery needs an assist to get the f...Show More
enblethenNomadAug 19, 2019PNW:Very common! The difference is whether the particular truck requires a wire to be terminated, fuse installed or hot from the factory.
Related ContentAdding power outlets in slide with no wiringNo power on outside GFCI outlet12v power problemsNewbie power question12 Volt Power Issue
