wuhungsix
Nov 11, 2014Explorer
16" LT tires now a subframe lift? UPDATE Subframe complete!
UPDATE: pictures of subframe on page 4!
So I originally created a post on upgrading 15” ST tires to 16” LT tires (https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27525229.cfm) and finally got around to doing this on my 2014 Forrest River Palomino Puma 259RBSS fifth wheel.
I went with BFGoodrich Commercial TA LT215/85r16 on 16” steel Dextar wheels. Old tires were Akuret ST225/75r15. I have plenty of clearance between the two tires but have about 1” of clearance on the rear axle from the top of the tire to the darco materiel on the underside of the trailer. I was going to drive it around town to see if and how much it may rub but have not had the time yet.
Now my trailer has never been level with my 2012 Ram 3500 SRW. It has come up a little with the added 1” in height on these BFGs compared with the old STs. But I’m sure I’m going to need more clearance with these new tires.
SO I have two options that I can tell,
LPI Correct Track which gains 2” or a full sub-frame build. I got a local quote for the Correct Track installed ($925) and another for a full sub-frame build ($750). I’m obviously leaning to the Sub-Frame build as it’s going to be sturdier if built correctly as well as cheaper. I initially wanted to tackle the Correct Tract install myself but don’t feel comfortable supporting the trailer up.
My question is, does anyone here run with similar (1-2”) clearance between tires and underbelly without any issues? I have a short camp trip in a few weeks and may not have time to get the sub-frame build done in time. Wondering if I can make it there and back or if it’s a bad idea. It’s about 250 miles back and forth on standard CA highways.
Here are some pictures of the new tires and wheels,
New and old tires side by side
New LT on left and old ST on right
Both new LTs installed
Old OEM ST set up
Clearance between wheels,
LT
ST
And how the trailer sits mounted with truck on old ST (no current pictures with LT tires)
Old OEM ST set up
LT
ST
