P_Kennedy
Nov 21, 2014Explorer
So in the end you needed a little more than 2" lift to level your trailer. They did a good job and the way they set it up you won't have worry about it coming off the way it is saddled into the spring mounts. You will notice it rides better as the pressure on both axles will be the same and the center of gravity is not that much different it just looks that way.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
