wing_zealot
Mar 29, 2021Explorer
mileshuff wrote:First, there is only two of us, second, a full load of gas is already accounted for, it's not part of the "Payload". Like I said, I have over 2100 lbs of payload left for tongue weight/pin weight.
How are the newer 1/2 ton trucks rated higher than my 2007 3/4 diesel? My max pin weight rating is right near 2100 lb. I have looked at the springs and diffs, axles etc on newer trucks and they are no where near as beefy as mine. So how the higher ratings?
How is the Rating higher? - you burned up payload on that diesel engine. The curb weight of my vehicle is substantially less then yours. Even the gas version of your vehicle gives you several hundred lbs more payload.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
