MFL
Mar 29, 2021Nomad II
mileshuff wrote:
How are the newer 1/2 ton trucks rated higher than my 2007 3/4 diesel? My max pin weight rating is right near 2100 lb. I have looked at the springs and diffs, axles etc on newer trucks and they are no where near as beefy as mine. So how the higher ratings?
Have you weighed your rear axle separately, to know how much pin wt can be added? Should be a lot more than 2100 lbs. I'm thinking you have around 3K lbs available, before going over your RAWR.
Jerry
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
