Grampatech's avatar
Grampatech
1998 Aljo 21.5 footer
Hello!
I just picked up my FIRST RV! She needs some TLC, but first a burning question...
Does anyone know where they put the 12V house power cut-off switch on this puppy? The landing gear works great, so I know the battery is good.
But...
The battery breaker is passing power out, but no cut-out switch anywhere they normally put them. No power whatever to the house. All converter fuses are good, and I know the fuse panel takes power from the converter or the battery. I haven't plugged it in yet---too far from the power post and I need to move it. But it should have 12V power without having to plug it in...
Any info would be appreciated. Have a LOVELY day!
Nick
Thanks in advance for your assistance!
  • Welcome to the forum.
    I don't have any specifics on this brand, but not all RV's have a battery disconnect. I had to add one on my 2018 TT.
    Some use a a manual disconnect switch, others use a solenoid with a remote switch, and some like mine have no factory disconnect.
    Hopefully someone with brand specific information will answer you. It would help if you post the full model of your trailer in your signature or post. I'm guessing based on the length indicated, its an M-2115.
  • I had a 24' Aljo Aly of similar vintage and it didn't have a battery cutoff switch.
  • Could be a circuit breaker, not far from battery, maybe on inside wall behind battery.
    Jerry
