dehaile's avatar
dehaile
2 year old Norcold refrig is dead w leaking cooling unit
I have a 2014 GD 355TH. It has a norcold 1210 4 door refrigerator. This is the notorious refrigerator that has a class action lawsuit (possible now settled for 33 million) for leaking cooling units that can cause fires/explosions and even some deaths. The manufacture did not do anything to correct the issue , they just issued a recall to install a heat temparature sensor that would shut the unit down if it started to overheat. Again, the recall did not address the issue of what was causing the problem, they just tried to stop the units from blowing up. You can google norcold class action for more info.
Back to my problem. My unit has a serial number that is not part of the class action (too new) It's cooling unit has failed with a least three pinholes that are leaking. I called the dealer and also a couple of RV repair places and they all said "good luck" but even if norcold sent you a replacement cooling unit , it would also fail. These cooling units are $1200-$1800 plus at least 5 hours labor to install. New refrigerators are 4K! I can't believe this !! We have such a nice RV with no refrigerator! I don't know what to do. BTW , this is not a Grand Design problem but I hope they quit using Norcold if they have not already. This is a major issue because some of these units have exploded even with the recall device installed. If you don't think that is a problem, then think about that RV neighbor of yours that is right next to you in the RV park with one of these ticking timebombs. I am trying now to decide if I want to try one of the amish built cooling units (about $2200.00) installed or go to a residential refrigerator. I have pictures if interested.
thanks for listening.
