LostinAZ
May 21, 2013Explorer
As I recall the 2002 F350 Dually has less towing capacity than a F250 because the dually is heavier. The only advantage is the pin weight on the F350. And if I also remember properly the total combined weight rating of the truck and trailer is around 20,000 lbs depending heavily on configuration such as 4WD, CC, etc. That would probably dictate a 5th wheel or trailer less than 12,000 to 13,000 lbs
About Fifth Wheel Group
