navajochief's avatar
navajochief
2005 Weekend Warrior FS2600 Wedgewood Oven Door Replacement
I need some help identifying a part. The oven door inside the trailer recently shattered as I drove over a very bump, rutty road. All that was left was glass spread all over the floor. Thankfully, it was the only damage that occurred. My question to those that have or familiar with the WW FS2600, what size oven door does it use? There are two options: 17" and 19".
Anyone ever had to replace the oven door as well? I'm stuck buying the whole unit as the glass can't be installed on the existing door.
Thank you.
  • You're going to replace it with the same glass? Aren't you concerned it will break again?
  • Found the invoice, mine must be an Atwood oven in the 2006 WW FSC3200.
    What I purchased from American RV was: Atwood 51881 Wedgewood Small Black Glass Insert Panel for RW and RA models trailer. So that's the 17" model.
    During my initial searches I thought I would have to replace the door too but then I found the glass alone and figured out how to remove the outside border on the door to put the new glass in.
    Good luck.
  • I did mine last year, really bumpy road plus a loose bird cage.
    I'm looking for the info, it was cheap (less than $30 delivered) and it was easy to install. I just measured the old door and ordered the one that size.
    There were only two screws holding the outside frame on the door from the top, once loose the glass dropped right in.
  • I think this is fairly common, I bought a sheet of 3/16" aluminum plate and cut to size, then painted BBQ black.
    Actually looks just fine.
    Stupid design as there is no way to secure the door shut so when you hit a big bump, it slams the door shut and you get to clean up glass.
    Thank you.
    most all toyhaulers use the 17" range. Our first one (1999 Wanderer) had the 19" range and my DW reminds me of that anytime she wants to bake something large. We could actually cook a small turkey in the larger one.
