mhardin
Nov 16, 2016Explorer
I had the same problem on my Jayco travel trailer. I drilled the lag bolt holes to the size of some wooden dowel rod I had and then epoxied the dowel rod into the hole. After the epoxy set up, I drilled the proper size for the lag bolts and reinserted them. Problem solved!
About Fifth Wheel Group
