laknox
Nov 16, 2016Nomad
mhardin wrote:
I had the same problem on my Jayco travel trailer. I drilled the lag bolt holes to the size of some wooden dowel rod I had and then epoxied the dowel rod into the hole. After the epoxy set up, I drilled the proper size for the lag bolts and reinserted them. Problem solved!
Dowel was probably harder wood than what the factory used, too.
Lyle
About Fifth Wheel Group
