corvettekent
Sep 04, 2021Explorer
I have the Nev-R-Lube bearings on my 2004 Carriage with around 100,000 miles. I have no problems with mine.
I called Dexter and talked to a tech and was told that to check them jack the tire off the ground and check for excess play in the bearing by grabbing the top of the tire and move it in and out.
If you do remove the brake drum you will need to torque the bearing to 140 ft lbs.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
