Michelle_S
Jan 08, 2014Explorer III
You have multiple 12V circuits, should be pretty easy to pull all the fuses and starting checking each line to see which line has the short. If there are multiple lines shorted (per the 90% down) then there is a major problem somewhere. Wires crushed under the frame, by a slide, etc. If that's the case the Factory is the only ones with the knowledge to fix or replace it.
About Fifth Wheel Group
19,027 PostsLatest Activity: Jun 19, 2019
