- NC_HaulerExplorer
Me Again wrote:
I just watched the Anderson video again. I did not see their safety chains? Ball connections require safety chains.
Here at the other things I see:
1. Have to raise trailer higher to couple and uncouple, just like other goose neck hitches.
2. Have to be spot on the connect, hard to hook up single handed, just like other goose neck hitches.
3. No one else can move your trailer, just like other goose neck hitches..
4. You can not move someone else trailer(Buddy System), just like other goose neck hitches.
5. Puts the load directly on the pickup's sheet metal bed, unlike a correctly installed 5th wheel hitch the transfers the load the trucks frame rails.
6. Factory hitch adds strength to the trucks rear frame, Anderson does not.
7. Puts stresses on the king pin that it is not designed for.
8. Four set screws are all that prevent it from turning on the king pin.
In my mind this is just another band aid like a goose neck adapter. Manufacturer voids thanking about the safety chain requirement. Remember goose necks require safety chains, and this is just a goose neck adapter moved high up from the bed floor.
Chris
Chris,
I have a couple buddies on the cummins forum that have this hitch and when I first heard about it, to me, it was just another GN hitch that I didn't want, but with the triangular base and hitch up in the air, it IS a 5th wheel hitch and doesn't require safety chains. and though you bring some good points to the table, after months and months of reports from those that have owned these hitches and towed with them and shared their real world experiences, I've yet to see any issues with them...
To move the 5er with a reg. 5er hitch, all one has to do is remove the coupler from the pin, and 5er can be towed with a regular 5th wheel hitch. I'm not sure if weight is put on the "bed of the truck, center ball is integrated into center hole, affixed to the frame, and, though I could be wrong, the frame of the hitch along with the 4 legs should all come close to straddling the frame, (not sure of this, but thought it was really close.
Again, not promoting the hitch, just stating, at one time, when those of us purchased this truck with the prep package, NO ONE could get a picture frame adapter to use their existing hitch with..thus the reason, with some research, those that NEEDED to tow with their truck, went to the drop in ball and andersen ultimate 5er hitch....possibly not the BEST alternative, but certainly one that was available, cost efficient and was capable of doing the job at the time.
Same can be said about my Reese 20K...some don't like liking jaws....as one poster called them, "Rick Krispies" hitches, (snap, crackle pop)....I've never in all the years I've towed with a Reese hitch had the first issue, no chucking and definitely no snapping, crackling or popping...
Bottom line, the Andersen was an alternative for those that Chrysler left hanging...gave us a prep package and no way to use it.....owners had to become innovative if they wanted to tow this past spring and summer and come up with another way to use the prep package and the drop in ball and Andersen hitch was a way one could do this..
ON EDIT: Andersen also makes this exact same hitch that will mount to rails or the picture frame adapter,
Again, I agree with Chris, I think hooking up to a conventional hitch would be easier than hooking up to this hitch, but I guess it depends on what you might want to get.. - gtsumExplorer
NC Hauler wrote:
gtsum wrote:
NC Hauler wrote:
gtsum wrote:
amazing to me ram puts out the prep package and there seems to be limited, if any, aftermarket uses for it (for a fifth wheel hitch)
One really needs to do the research....almost any GN hitch works in the center hole, there are several hitches that take a drop in ball that will work in the center hole..
Then you have the picture frame adapter that will take just about any conventional 5th wheel hitch..it's there for the research and believe me...after ordering this truck in Dec....getting it in May, not getting a picture frame adapter until July....and in between trying to figure out what I should or shouldn't buy or should or shouldn't wait for...I do know a little bit about this topic.
There are quite a few, quite a few 5th wheel hitches that work with the GN/5er prep package from Ram....there are even more GN hitches that will work in a heartbeat and there are more than several hitches that sit onto or lock onto a drop in ball that will work.
One can purchase a Reese Elite drop in ball for under $200, then purchase an Andersen Ultimate 5er hitch for $449 , (free shipping on all), and in about 20-30 mins, you're ready to roll.....that option was figured out before the picture frame adapter was available.
"limited, if any, aftermarket uses for it (for a fifth wheel hitch)?.. Far from it...again, a little research proves this to be in incorrect "assumption"...
My apologies. I had seen where a few people were running the anderson hitch and it looks simple (almost too simple??), but I am a newbie who doesnt know much.
I would like something like the B&W Companion hitch (or comparable for a 14k GVW fifth) that can be easily taken out and installed within minutes for a fifth wheel. So that when I take it out within those few minutes, my bed is perfectly flat with no rails, etc. Is that is what is being developed right now, or is that already available. I have tried to research it, but perhaps I am getting confused from all the different companies?
It's already available...I remove my 5th wheel Reese Signature 20K hitch from the picture frame adapter, remove the adapter and my floor is completely empty...no rails, nothing.
The Andersen Ultimate 5er hitch is another one with the drop in ball in center hole of GN/5er prep package and the Andersen Ultimate 5er hitch, can also be put in and removed within a matter of minutes.
The only bummer with the B&W Companion hitch is that it takes a square shaft to hold it into place, where as the center hole for the Ram 5er/GN prep package comes with a round center mounting hole.
If your truck DOESN'T come with the GN/5er prep package, you can add the B& W mounting hitch and all is well....if you have the round hole, there may be something you can replace it with, but at this time, I'm not sure what.
But again, even with the picture frame adapter and a 5er hitch mounted to it, I can remove the hitch and picture frame adapter and have a completely empty bed in about 10 mins. No big deal and a lot of different 5er's DO fit the picture frame adapter...
You are correct, the install of the Andersen hitch is SO simple, even a cave man could do it::.....doesn't mean it doesn't work...more than several are using them on the cummins forum, easy in, easy out and some towing quite heavy and there doesn't appear to be any issues...."IF" opt to go another route down the road, I may very well sell my Reese and my picture frame adapter and go with the Reese Elite drop in ball and the Andersen Ultimate hitch...it's a true 5th wheel hitch and I wouldn't hesitate to use it....and it's lightweight.
Thanks for the clarification. That makes it easier for me to understand! - Me_AgainExplorer IIII just watched the Anderson video again. I did not see their safety chains? Ball connections require safety chains.
Chris - NC_HaulerExplorer
Gunship Guy wrote:
I ordered our '13 with the factory hitch package. The dealer threw in the picture frame adapter for free. It's still in the box. I have no intention of ever using it.
I installed the Andersen Ultimate 5th wheel hitch. I can describe this hitch with one word. Amazing.
I was skeptical at first since it's unlike any 5th wheel hitch on the market. I did extensive research and spoke with Andersen reps. After towing with it, I will never go back to a conventional 5th wheel hitch. It's just that good.
No jerking or chucking. Extremely easy to remove from truck when full use of the bed is required. Installs in under 2 minutes (yes, I timed myself).
Specifics I like:
-Simple
Keep telling people this, glad you tossed that out there. First one I heard of was over on the cummins forum back in May or so...guy from TX towing fairly heavy.....since then, quite a few have went that route, and again, I came really close, and eventually may go that route. Teh hitch only weighs about 40# or so, if not mistaken...
heck, if you're going to can the picture frame adapter, odds are you could make a little money off it..there are still people in process of trying to buy one.
-Extremely strong
-Uses trailer's factory hitch/king pin
-King pin block is easily removed so trailer can be towed with conventional hitch (if you take your 5'er to a dealership for service, etc)
-Inexpensive
-Truck bed space loss is minimal. Small items can fit under the hitch, if necessary.
-I have more than enough space between bed rails and trailer nose. Need to measure, but it looks like about 8".
-No grease/lubrication is needed because there are no moving parts. Hitch stays dry and clean.
I certainly understand the confusion and skepticism out there over this hitch. It's something people aren't use to seeing. But that's the way it is with everything new and different. - Gunship_GuyExplorerI ordered our '13 with the factory hitch package. The dealer threw in the picture frame adapter for free. It's still in the box. I have no intention of ever using it.
Specifics I like:
-Simple
-Extremely strong
-Inexpensive
I certainly understand the confusion and skepticism out there over this hitch. It's something people aren't use to seeing. But that's the way it is with everything new and different. - NC_HaulerExplorer
You are correct, the install of the Andersen hitch is SO simple, even a cave man could do it::.....doesn't mean it doesn't work...more than several are using them on the cummins forum, easy in, easy out and some towing quite heavy and there doesn't appear to be any issues...."IF" opt to go another route down the road, I may very well sell my Reese and my picture frame adapter and go with the Reese Elite drop in ball and the Andersen Ultimate hitch...it's a true 5th wheel hitch and I wouldn't hesitate to use it....and it's lightweight. - glazierExplorer IIMy gooseneck hitch looks like this Reese Signature Series Gooseneck Platform
I am not sure these would lock into the "picture frame" as refered to, but it certainly has 4 Cams on it.
You are correct I do not own a Ram - gtsumExplorer
I would like something like the B&W Companion hitch (or comparable for a 14k GVW fifth) that can be easily taken out and installed within minutes for a fifth wheel. So that when I take it out within those few minutes, my bed is perfectly flat with no rails, etc. Is that is what is being developed right now, or is that already available. I have tried to research it, but perhaps I am getting confused from all the different companies? - NC_HaulerExplorer
glazier wrote:
tinner12002 wrote:
I actually have the gooseneck hitch that cam-locks into the same frame the 5ver hitch locks into. 5 min switch over. Great setup in my opinion!
Same here, I have a Signature Series Slider hitch, and a Signature Series Gooseneck Platform, great setup. Fast change, and very strong.
So you two have a 2013 or 2014 Ram with the GN/5er prep package and one of you have a GN hitch that locks down into 4 different cam locks holes, (never seen that), and the other has a Siganture Series Slider hitch and a Signature Series Gooseneck platform and it too locks down in the 4 outside holes that are offered with the Ram GN/5er hitch cam lock holes. Neither of you use the picture frame adapter??., (you don't need the adapter ?)
Haven't seen a conventioal GN hitch that needed 4 seperate cam locks, normally, they just need the center hole..
Maybe I'm misunderstanding.....one picture is worth a thousand words:)
One picture is worth a thousand words:) - glazierExplorer II
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
