Road_Phantom
Oct 27, 2018Explorer II
I had a 2011 Cougar 1/2 ton tow-able. The problem with them is that they sit low. I think you'll find that when you hook it to your ford 4/4 the trailer will sit nose high, putting excessive wear on the back axle. I believe this was the case last April when the left rear wheel come off the trailer and wound up laying on the double line of Main St Biloxi. The bearing failed, and it been hand repacked that prior summer. You may be able to get spacers for the springs to lift the trailer up high enough without flipping the axle, which is something I'm not a fan of. Otherwise, your truck is more than enough to tow that trailer.
About Fifth Wheel Group
